Everything posted by 06SubLegTx
- SOHC 2.5i Subaru Official Crank Pulley Bolt Procedure
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey, thanks for being honest, I have only had 2 subarus so I am kinda new to these engines.... I wonder why Subaru do the 65 degree thing. Wondering if is a bolt that stretches to stay tight...
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD, okay just wanted to know why... I like learning from other people.. thanks
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy do you go to 150 ft-lbs, when Subaru only says it needs 132.8? Just curious why you do it.
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you torque your to 150 ft-lbs? Subaru only call for 132.8 ft-lbs Why do you go more then?
I found this in my Subaru Manual. Page 242, What I rarely hear or read what people never do: Step 2 under Installation. 13.Crank Pulley A: REMOVAL 1) Remove the V-belts. <Ref. to ME(H4SO)-36, REMOVAL, V-belt.> 2) Remove the crank pulley bolt. To lock the crankshaft, use Shop Tool 499977100 CRANK PULLEY WRENCH 3) Remove the crank pulley. B: INSTALLATION 1) Install the crank pulley. 2) Install the pulley bolt. To lock the crankshaft, use Shop Tool 499977100 CRANK PULLEY WRENCH (1) Clean the crankshaft thread using compressed air. (2) Apply engine oil to the crank pulley bolt seat and thread. (3) Tighten the bolts temporarily with tightening torque of 44 N·m or 33 ft-lb). (4) Tighten the crank pulley bolts. Tightening torque: 180 N·m or 132.8 ft-lb) 3) Check that the tightening angle of the clamp pulley bolt is a minimum of 65°, Perform the following procedures when less than 65°. (1) Replace the crank pulley bolts and clean them. Crank pulley bolt: 12369AA011 (2) Clean the crankshaft thread using compressed air. (3) Apply engine oil to the crank pulley bolt seat and thread. (4) Tighten the bolts temporarily with a tightening torque of 44 N·m (4.5 kgf-m, 33 ft-lb). (5) Tighten the crank pulley bolt keeping them in an angle between 65° and 75°. NOTE: Conduct the tightening procedures by confirming the turning angle of crank pulley bolt referring to the gauge indicated on timing belt cover. Thoughts?
Intake off or On during reinstall
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree... off it is
Timing Belt installed Gears lined up
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have...NO Interference. Next, timing cover, rocker covers, spark plugs and then back into the car... 2 months this has been going on...
Whine when letting off accelerator
06SubLegTx replied to skjeflo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI understand, I lived in Queen Ann, Capital Hill, Bremerton from 1997 to 2008 Has the car ever been thru deep water like to the center of the wheel? If so, the seal may have leaked and cause contamination of the hub/wheel bearing. Have you ever change the front and rear differential gear oil?
06SubLegTx replied to skjeflo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on the car? Do you live in snowy are rainy area?
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeap, just want to make sure I didn't do something wrong. It is a 2006 with 99k on it. Bunch a new stuff, previous owner let a non subaru shop work on it... they used impact wrench on tensioner that was failing (leaking fluid), bolt got a stress crack.. it broke on me after only owning the car for a month... 4 valves bent... no fun. fyi, I have Bilstein B6 Struts and Shocks going on after I am done with the engine.
- Timing Belt installed Gears lined up
06 Legacy easy way to drain Fuel Tank?
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGas was not in long enough to go bad..
06 Legacy 2.5i SOHC Tappet Adjustment
Hello, When I am doing my Rocket Arm to Valve Stem clearance. Should the Feeler Gauge have some resistance when I pull it out after tightening the Locking Nut, or should it slide out easily? Thanks
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMatt, Whats your reason(s) for toing it this way... just curious because I am a newbie.. Thanks
More SVX questions..
06SubLegTx replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I remember correct, a company/guy on the net use to rebuild the transmissions... it would take a little searching to find him, maybe he still does it.
Is easier or harder to reinstall the engine with intake manifold Off or On? I have a Strongway Lift with Engine leveler. My concern is the chain hitting Ignition Coil Thoughts Thanks, Mike
06SubLegTx replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere was a guy in Oregon who actually made a complete swap kit. If the lookup SVX with Manual Transmission they tell you what is needed. I also remember reading on a SVX site that a guy had pics of one that was completed
- 06 Legacy easy way to drain Fuel Tank?
Water Bypass "Rubber" hose Install
06SubLegTx replied to 06SubLegTx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks it worked great
- Water Bypass "Rubber" hose Install
