Everything posted by SovereignMK
Correct NGK plug number for 1.8OHC?
I just tossed them in:-\ It's supposed to be.044 iirc right? //M
Ok, I've checked and everything says it's the right part #. Though I'm getting a sputter like somethings not firing(guess) after changing the plugs(BPR6ES-11 was in there previously). I've pulled the wires and plugs and redid it but still a rough idle and has the tendency to die. //M
Is BPR6EY-11 right? //M
engine pinging/knocking problem with EA82
Oooo, Have any pics pointing that one out? Is it like the PVC valve? Rookie here, needs a map around the engine bay. //M
Help...alternator problem..?
SovereignMK replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan't remember which second gen's (95-99) were affected but I got a new alternator under a Subaru Recall for my '98.
I get pinging in hot weather if I run anything less than Premium on my 86 Wagon(EA82). Going to find out if it's true for cold weather as soon as it gets here.
Fuel Door & Other Questions
Fuel door anwser. //M
Good Fix for window streak marks?
Thanks for the info, Looks like I get some new glass at the junkyard and then test the buffing on my old stuff. Will let you know. ///Mark
For those of you that get the streaks from the rollors pushing on the window glass(power windows), have any of you found a good fix (besides replacing the glass). //Mark
XT6 Clutch Kit in '86 GL 5sp Right?
Thanks XSNRG! I remember searching for the info and coming up with that thread and assumed it was a direct swap too, though being a Brat with a EA82, I didn't know if that came into play. So basically, if I get a XT6 clutch kit (includes flywheel right?) it should pop right in? //Mark P.S. No Haven't meet Barracuda yet. But I would like to get a Eastern WA / Idaho meet together before the weather gets too bad.
Eastern Washington/Idaho meet?
Bonners Ferry is quite a drive from Indiana:D //M
Come on, Needing some help guys!:drunk: :-\
Anybody want to help a new guy? //M
Air suspension
SovereignMK replied to Mike W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be a button on the dash that will rasie the "rear" when you put cargo in the back. //M
Ok, I need some ressurance that the XT6 Clutch kit will work as a replacement for my slipping GL clutch. I'm really a noob on my GL compared to my Legacy so help me out guys:D Is this a go? And what were the benefits again? Thanks. ///Mark 1986 GL Wagon 5spd with 4hi/4Lo 223000mi
What's the difference between a gl and a loyale?
So are most body parts swapable between them? Headlamps/Bumpers/Window Glass? //Mark '86 GL SpeedWagon
Best Clutches for an 86 4wd Wagon
^^^Anyone? //M
I'm thinking an ACTclutch, but don't know if they make one so.....Pretty much as the subject states, need some ideas for aftermarket or is OEM still a good way to go? //Mark
I know you people are hiding out there, it's ok now, you can come out of your caves:D //Mark
Don't know if any of you guys get together but I'd like get something setup before it gets to cold. //Mark
Top Ten Things To Do when....
Also, Anyone from Spokane? //M
you pick up a 1986 GL Wagon. Looking for some good recommendations for this commuter Speedwagon:D (Performance, Preservation/Upkeep, Accessories, Anything really and if need be there can be more than 10......) //Mark
Front Brake Pad Replacement on 86 GL
I saw those to caliper assembly bolts (17mm) and took one out, but was thinking it should be simpler than that. Oh well, now I know and knowing is half the battle! Thanks stephenw22! //M
That long bolt was what I looking for (like my 98 Legacy) and found, though I did't see the top bolt for the caliper to pivot on -- I must be missing something. //M
Well, I know who to come to for engine help.... //M
