Everything posted by quentindc
Cooling System not working properly - Tried everything.
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi All, My Mechanic friend took the car back to the garage, he told me the heater core was fine, he did several pressure tests and for him the HG is fine too. He talked about this to a friend of his who is a Subaru Mechanic who hopefully can have a look. Meanwhile I have been driving without Tstat. I know it's not the best but still better than having a Tstat constantly closed. Keep you guys posted.
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it's overheating because when I let the car idling for 45 min or when I drive for like one hour, the lower hose is still cold ans fans still don't work. The upper hose it really burning hot and the engine block as well. My Mechanic friend tested it with his infrared thermometer and told me the heat should trigger the fans / open the thermostat (which was happening like 6 months ago after 15min of idling). Thanks for your inputs, I'm gonna look into all this. I am still wondering, when I remove the thermostat and leave the car idling for like 45 min, the fans still don't turn on. The coolant flows fine and the engine heats at a temperature which should trigger the fan (it was the case 6 months ago). Also of exhaust gas come in the circuit, I should see bubbles coming out of the radiator when cap removed ?
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just checked the oil and coolant, I changed both this week and drove around 1000km and after checking they both look clean, thats it. The temperature gauge never went above the optimal temperature value. In case it my HG would be starting to get bad, it still would not explain why the thermostat does not open right? thanks a lot for your inputs guys, I'm gonna look more into a head gasket. If anyone can explain the link between bad HG and a thermostat not opening despite high coolant temperature that would be great. Thanks
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I bought an original Subaru one, tested in hot water it works fine. ANd yes I put it in the right way, it does not fit the otherway anyways . Plus i has such a hard time removing the other one i remember i had to pull on the upper part, and the spring section was up in the engine.
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Twitch, I checked all hoses with and without thermostat, no ccollapse :/ . With thermostat in the bottom hose stays cold and top one super hot, and there is no pressure in the radiator.
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey guys, So to answer your questions: Twitch: I'm going to start with the stupid, easy to overlook stuff. I do this to myself, so don't be insulted. Not at all, thanks Have you checked your fans to see if they're plugged in? Yes, they work fine when testing relays Are the wires broken or cut to the fan? No they are intact Have to checked your hoses to make sure they're not collapsing while under load/suction? THey are fine even under pressure, the coolant flows well without thermostat Did you replace your radiator cap? Yes Did you replace your water pump on your last timing belt change? Yes, 20,000 km ago Did you make sure your coolant isn't disappearing? Yes there is no leak anywhere, even after driving for long Does the coolant level in your overflow tank fluctuate dramatically between hot and cold operation? Beyond the normal range indicated on the reservoir. When driving without thermostat, fluctuates normally, when thermostat on, doesn't fluctuate at all as Stat stays closed Have you tried filling up the coolant system by filling the block then the radiator? No, haven't tried this, but coolant goes through everything I checked Are you using the right mixture of coolant to water? Yup, followed the constructor manual Did you lose a rag when you were doing any of this work on it? Good one : D but no I have all my rags Forester: Have you checked the fuse(s) and relay(s) that feed the fans? Yes, I checked everything, the fuses are good, and the relays are good too (used the test wires under dash to test them, they all click and activate the fans when tested).
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
quentindc replied to quentindc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUp
- 41 replies
- thermostat
- sensor
- sender
- cooling
Tagged with:
Hi Everyone, It’s been 2 months now of researching, reading every thread I can, trying, monitoring with no success; I am now totally stuck and don’t see what else I can do to solve my issue, and this is driving me mad ^^ ! I have a Subaru Impreza Hatchback 1998, EJ15 GF1, manual, petrol, with now 190,000 km. Small engine, pretty well maintained, I change all filters and oil every 10k since I have it, the previous owner was taking care of it and I bought it after the cam belt and water pump were changed professionally by a garage., around 170k. So one day (around 187k) I noticed the car smelled a bit like overheating engine. I checked under the bonnet and noticed that the fans were not working. After more in depth checking I noticed that the lower radiator hose was cold and there was no pressure in the radiator. So bought a new thermostat and gasket (original Subaru) and new coolant, tried it with the new one and didn’t change a thing, the damn thing stays closed. Tested both thermostats in hot water, they both work fine. I then tried to run the car without the thermostat, I get good pressure, the coolant is flowing, I could properly burp the cooling system and I could see the radiator was not clogged, but surprisingly the fans still did not turn on. So I bought new temperature sensor and sender and tried again, but nothing changed, the fans don’t turn on. I checked all the fuses, under the steering wheel and under the bonnet, tested the relays with the test wires under the steering wheel and both relays and fans work fine. (I also bypassed the relays with fuses and this turns on the fans, no problem). The very weird thing is that when the thermostat is installed and the engine running, the temperature gauge comes up to the optimal position, slightly below the middle, and stays there, even though the engine keeps heating. I don’t have an infrared thermometer but I can tell by the smell and the heat, and the fact then the thermostat stays closed and fans stay off, that something is wrong and that the engine is too hot. It really smells like overheating engine and the hoses and engine are reeeeally hot. Before this began happening, when it worked well, the fans turned on and off automatically and I could tell when the thermostat opened and closed, it was all fine. I tested all sensors, new and old, with a multimeter and they all work fine, even the thermostats in hot water both open and close correctly. I contacted a mechanic friend who checked everything, he used a pretty strong product to clean the cooling system in case there would be some kind of stop-leak or stuff clogging the system, but nothing, the circuit is clean. I even used a thin brush to try to clean possible depot around the sensor areas, but nothing came out, all is clean… I also cleaned the cooling system with my garden hose, I know it's not recommended but I was out of options, I confirm that water flows through everything and came out clean. (I rinsed with demineralised water several times after this and put new coolant). I feel like I did everything I could, I don’t see what else to do. I am not sure this could be related, but (I think) this began happening the same month that someone tried to steal it, or at least I noticed this cooling issue like a month after. No big issue from these unskilled robbers, who just broke the door handle and damaged the ignition, but it took me like 2 weeks to fix this, but during this time I removed the battery from the car because I could not close it and I don’t have a garage. So the car stayed quite a long time without a battery. I thought this could have done something to the ECU (I have nearly no knowledge about this part of cars) but anyways, this should not impact the thermostat which is a purely mechanic part. So Guys, I don’t knot what else I can do. I am pretty sure that the radiator is fine, I have been driving without a thermostat since, the engine takes longer to heat and the temperature tends to decrease at high speed and increase at idle and low speeds (no fans working, remember) which seem logical to me. Also the heater core seems fine, heat turns on and off, no problem. If you have any idea what might be going on I’d be super keen hearing your opinion, this is getting so frustrating. Cheers guys, thanks for reading ! Oh and it's not a head gasket by the way, already checked, oil and coolant are fine, I changed both.
- 41 replies
- 2
- thermostat
- sensor
- sender
- cooling
Tagged with:
