Everything posted by divinicus
- Cyclops 3rd Eye Install!
Thanks for your help, again! As I wrote earlier in this thread, I have both types of relays. According to Chris' DPDT Relay plan, he calls for the use of an 8-pole relay. I purchased two and they are very easy to source. For clarity's sake, I'm going to draw a schematic of my own, which follows the 8-pole DPDT Relay, the original wiring harness and the original "Center Lamp" switch. This way hopefully everything will be laid out for other folks to follow if, like me, they have the switch and the cyclops light but are missing the original factory relay PCB. UPDATE: A friend offered to send me his original 82 Cyclops Front Grille! So as the job progresses I will upload photos and I hope this helps the group!
I saw those schematics, thanks! I could actually go either way being that I have both kinds of relays, but it seems to me the easiest way is with Chris' plan which seems like the easiest wiring job. Also it appears with his the cyclops can be used with either high or low beams, no need for a second auxiliary switch. Since I have an 83 Brat GL with four headlamps, I pity the poor driver in the opposite lane when the highs and cyclops are on together, lol!
Update I ordered an 8-pole dpdt relay like the one you pictured. Also just tested my unit with bench top dc power supply. Both the motor, acuator arm and even the original light work! I noticed the motor runs continually and assume the relay will tell it to cycle when the switch calls for power, raising the door, and when I power it off with the switch, that the motor will cycle to close the door. Really excited with the progress and thanks for the help!
Just got a working cyclops 3rd eye setup for my 83 Brat GL. Have the original switch, but missing the original relay pcb. Also don't have the original 82 grille that matches the cyclops. Purchased a set of 87a relays and have read posts here how to wire these up using the original switch. Can someone please reply with a working, known to be good spec for getting this setup working? Also would be very interested in purchasing an original cyclops front grille. Thanks!
