Zip Tie
Everything posted by Zip Tie
I pulled the pistons this morning and besides being really dirty the look fine. After I clean them up I'll get a better look at the ring lands to check for cracks. One thing that did catch my eye was the condition of the wrist pin bearings. Correct me if I'm wrong, but they shouldn't have that copper color to them.
GD I understand. And the more I clean on the block the more signs I see of someone already having cracked it open (ultra black pushing out of the seams). I took the heads in to an engine shop today to get resurfaced, cleaned and pressure tested. The old dude in there took a quick look at them and said it'd probably need new valve guides and seals and it was probably burning oil pretty good. I showed him this picture and he said there might be a problem with the piston skirts rubbing on the cylinders (see photo, 5 o'clock in the cylinders). He said I definitely needed to check the rings because the clean sections on the piston meant oil has been getting through there. And measure the piston skirts at the same time.
I found this guys YouTube channel last night and he seems to be doing what I am going to do. It seems pretty informative and straight forward (he doesn't appear to measure anything on camera, which is a little concerning). What do you guys think? https://www.youtube.com/channel/UCagMQRJltkIanI3KK1o5D7w
I know this is heresy to most of you here, but it's happening. No, I can't just go find one for under $300. I live in rural northern California and this one took almost a year of looking to buy locally. I got it already pulled from "a good running car" from the junkyard. The cars odometer read 268000. They didn't have compression numbers so I checked them (all 4 around 100). So I squirted a little oil in the cylinders and the numbers went up to around 120-130. I pulled the heads and there is carbon build up on the valves and pistons (although the pistons are clean in places on the edges). So, what I'm wanting to know is what's a good rebuild kit and any tips or tricks to make this engine come back to nearly new again.
Thanks for all the info and input guys. I'm going to do the head gaskets along with all the other stuff mentioned. It would be my luck that they blow as soon as I put it in the car. Right now I'm working on figuring a way to do a compression check while it's on an engine stand (cold obviously). Also, what numbers am I looking for?
Right after I posted this I found a ej22 at my local junk yard. It was pulled from a 95 legacy that was rear ended and totaled. It has 268,000 on it but was checked out before being pulled and was labeled "a good runner". They couldn't find any compression numbers for it though. I'm just gonna replace head gaskets, timing belt assembly, cam seals and main seals. Anything else I should replace?
How do I put this moulding back on?
Zip Tie replied to Zip Tie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I went through the hole in the rear cargo floor area and squeezed the clips out. They are not easy to get to. Thanks for the help guys. -
I guess this piece was loose and my toddler found it and removed it for me. The white pieces spin. So is there a position they need to be in? How do I get it back on?
Late 90's impreza seats in my loyale
This is the rail on the other side of the impreza seat. No flat bar to mount to, it attaches with that bolt in the top of the pic. -
I've done the reading on the process of the seat swap from kdixey but I'm a little confused looking at the bottom rails on the impreza seats. I'm seeing only one bent rail that I can attach the loyale rails to. Am I missing something right in front of me?
