bratboy1
Everything posted by bratboy1
  1. Ok got it with the brake rez! And with regards to the fans, I don't really understand your lingo and terms, so correct me if I am wrong, but if I leave the fan wires and connectors in the EJ loom, plug em in, and don't change anything else, the fans will run when I start the car. Are there any other connectors that I missed when labeling and figuring out what I need? Also what would you suggest with the fuel pump? Thanks! Sorry to keep bothering you!
  2. No need for brake rez? How come? Also yes 12 is much smaller but it was with 11 so I will keep it there. In regards to the fan, the EA wiring only has one fan connector whereas I have 2 on the EJ and I have a couple of fans so I thought I would just use those instead. Can you think of any other connectors that I will need to include? I know the fuel pump is one but that was on the secondary loom so I may have to cut down that other loom for the sake of including the fuel pump. Thanks for the help!
  3. 6- Pretty sure thats the Ignitor 7- The MAF 8- The 02 Sensor 9- The relay rack 10- Select Monitor? Idk about this one again was from here: https://www.busaru.com/subaruvanagon/wiringharness 11- These two big boys going to the engine 12- This guy also goes to the engine near the other two in pic 11 Thanks guys!
  4. Hey guys, First of all I would just like to say thanks for helping me out with all my questions. I am sorry if they are repetitive or dumb, I am trying to not make a major mistake with a critical part of the ej swap (wiring harness), and I don't know much about wiring in general. I made a huge mistake with not properly labeling the connectors as I pulled them out, it was a rookie move and I am paying for it right now. After the advice from this thread I posted last week: https://www.ultimatesubaru.org/forum/topic/169862-ej-swap-wiring-harness-question/?tab=comments#comment-1407906 and from this build which the EJ going into a VW bus: https://www.busaru.com/subaruvanagon/wiringharness and from this link found on the waybackmachine with the EJ into a VW bug: https://web.archive.org/web/20111012163255/https://www.shoptalkforums.com/viewtopic.php?f=28&t=136053 I have decided to go and label the connectors that I though were necessary, and go from there to figure out what I haven't identified yet/figured out, to improve my chances of not messing up lol. If there is anyone that can point me in the right direction after this I would be greatly appreciative. I have only cut out the cruise control and cruise control relay. For reference this is a 1991 Legacy. Here is what I have identified: 1- Brake Rez 2- The 3 sensors all together, cam and knock sensors I believe 3- The 2 green check engine and 2 black diagnostic connectors that are found together 4- The double diode. Not sure what this does but this guy said he needed it: https://www.busaru.com/subaruvanagon/wiringharness 5- Sloppy pic but Fan connectors And I will include more pics in the comments due to file size restrictions. Please correct me if I have labeled the wrong connector and/or left out one that is needed. Thank you so much I am really grateful for all the help!
  5. Cheers mate I appreciate all the help! Let me know if this is okay or not please.
  6. Dude that pic is great! And its got 4 yellow connectors into the ecu. Are those all the connectors I need?
  7. I can get it tomorrow mate! Its from a 1991 legacy. Let me take a look tomorrow, what number exactly am I looking for? Thanks!
  8. Yeah I was not about to cut the harness up like that lol.... I kept the shielding and thats all going to go back on after the harness is cut down. I will take a look at the numbchux guide and god from there. Thanks for the help! If I have anything else do you mind if I message you? I appreciate it.
  9. Yeah and mine is even stripped of the shielding and tape so its a big jumble of wires at the moment! Thanks for the help!
  10. So what I did for the cruise control is snipped the wires at the unit, followed them back as far as possible, and cut them off there. Those were the only ones I knew for sure I didn't need on the harness. This is from a 91 legacy btw. For instance do I need #11? That is my problem I actually dont really know what I need and don't need, I was going to include what this guy has here: https://www.busaru.com/subaruvanagon/wiringharness I can identify the connectors in that guys post, but I cannot really identify any others, so I was worried about cutting out something I really need lol. I am sorry if this post is vague or not really easy to work with, I am VERY new to all this and feeling a bit overwhelmed which I am sure is normal. Also i found this on the wayback machine: https://web.archive.org/web/20111012163255/https://www.shoptalkforums.com/viewtopic.php?f=28&t=136053 which has been a bit helpful. The two references that I just linked have different things they keep, but neither is swapping the ej in a 82 brat like I am so that is where I was getting lost. Thanks for all the help I appreciate it.
  11. This is the EJ harness yea. I guess my question would rather be what connectors do i NEED? Here is a reference that I was using but I was not sure if it was complete or if I needed anything else:https://www.busaru.com/subaruvanagon/wiringharness This guy is putting the ej in a VW so I was not sure if it was exactly the same, I am sure it is similar. I know I need things like the MAF, O2 sensor, etc. but I was unsure of what was the bare minimum. Thanks
  12. More pics here: I know 11 went to the clutch but when swapping the ej22 into the brat is it necessary?
  13. Hey everyone... I may have messed up here and I am looking for some help. When I was pulling the harness from the donor car, I was not to knowledgable about what every connector was and I didn't label them accordingly, just the ones I knew. I am currently stripping my harness, and the only thing I have cut out so far is the cruise control. I have a bunch of pics and if anyone could help me identify some I would appreciate it a lot! I have numbered the connectors in questions, if there are more later on I can always upload more. I will also comment with some due to file size restrictions. Thanks!!
  14. Does this carter fit in the pre existing location?
  15. Hey guys, I am going to look at a 2006 Subaru Baja soon and that has 127k miles and is a stick shift. It looks pretty clean from the pics, but is there anything to keep in mind when I'm going to look? The Baja is listed for $5k. Thanks for the help!
  16. Thanks a bunch guys I am pretty new so some of the lingo is not very easy to digest to I will try looking around for the suggested tips you have all mentioned! Thanks!
  17. Hey everyone, For those who have knowledge on the swap, what fuel pump is a good option to put in a Brat that is being swapped with an EJ engine? Inline is usually the way to go right? Also if you have any tips and/or tricks on how to do this I have never done this before and could use some advice! Thanks a ton!
  18. Okay man thanks! Hey... did you write that conversion manual? If so thanks man that is the best damn piece of literature I have ever read!
  19. What would be a case where you need the wire but not the connector?
  20. Hello everyone! I am a newbie when it comes to this so I just wanted to clarify before I do something dumb lol! I am swapping a '91 Legacy EJ22 engine and 5 speed in my '82 brat. I have the wiring harness stripped of the tape and shielding. For reducing the harness, am I just finding stuff I don't need and cutting off the connector, then taking the wires and following them back as far as possible and cutting them off? I just want to be sure before I do anything drastic. Also, I can run two different harnesses, the preexisting one in the brat in addition to the new one correct? With the EJ22 harness I wasn't planning on having the lights and stuff included since I have them already hooked up on the old harness. Thanks for the help! I appreciate it! Cheers
  21. Hello everyone! I am redoing my clutch on my 1991 Subaru Legacy fwd and this is the kit I bought: https://www.carid.com/sachs/clutch-kit-mpn-kf738-01.html?singleid=1711581778?utm_source=email&utm_medium=order&utm_campaign=order_notification_mail The new throwout bearing is just ever so slightly to small for the sleeve that it sits on, like maybe just 1mm or so. I am not sure if they changed the sleeve mid year or something, but I cannot for the life of me find somewhere that will sell the sleeve. Does anyone know about the size difference or where I can get a sleeve? I was thinking about getting the sleeve lathed down a little to make it fit if all else fails but I hope not lol! Thank you for any help!
  22. Do you have any tips or tricks to put the EJ inners on the EA shafts? Or do they really fit easily? Thanks mate!
