xXArchusXx
Everything posted by xXArchusXx
  1. I have to give mine gas when starting cold. revving to 2k rpm for 10 seconds should keep it alive. inspect the spark plugs and make sure you have spark.
  2. For dorman is there a part# for the silicone rubber boots? Can't find it.
  3. Any good places that sell supplies and have decent warranty?
  4. What stuff do i buy to refresh the axcles? its a fwd 88 XT6. do i have to pull them out of the tranny and drain the tranny fluid? new to this job.
  5. The pic is to the left of the brake pedal USDM. What else could it be? Unplugged each thing one at a time and the hazards still worked.
  6. Did that. The hazards still turned on.
  7. The lights turn on when u use turn signal doesn't flash and the hazards don't flash. It is 32 year old car after all. Where can I get a diagram for the fuses?
  8. The fuse box is just fuses and is fine. Underneath everything is just wiring. The ashtray thing has a blue box.
  9. I have a 88 xt6 and don't know where the flasher relay is. What kind of relay do I buy? The hazards and turn signal lights turn on and stay on and don't flash and it screeches at you. Guessing it's under the dash. Has somebody done a tutorial?
  10. I have a 88 xt6 and don't know where the flasher relay is. What kind of flasher do I buy? The hazards and turn signals stay on and it screeches at you. Also the automatic seatbelts don't work for the drivers side.
  11. The passenger side kicks back with the tool. The drivers side is broken off.
  12. It comes out. There is a square knob.
  13. Mine is like this I have an 88 what year is yours?
  14. That's what I have I don't see a hole.
  15. i took the seats out. where can i find the flasher for the fuse box in the repair manual i cant find it. there is a metal bracket hanging down on the passengers side whats that? is there a cabin filter?
  16. can i get new door switches and how do i know if they are bad? i found the tool but I couldnt find a hole anywhere.
  17. the seats are out and I found the tool in the bag but i cant find a hole to put the tool to move the automatic seatbelts on either side. where is the flasher relay? the two things in the picture fall out if you move them.
  18. the blend door hot to cold was one cable and had to take the center console up, there was a lot of sludge. it took 2hour. should the ebrake plate be diagonal? the top lights dont turn on when you press them. The drivers seat has a cable under it what does that go to? the windows take forever to move, and the passenger only moves with the engine on. the back seats should fold down right? What is the speed warning switch? where can i get a digital copy of the owners manual? iin cleaning the interior tomorrow.
  19. the interior lights dont turn on at all even if you flick the switch, but the trunk light turns on tho.
  20. these were in the center console what are they? i also have the original key box but not the original keys or anything for the box.
  21. thanks. its definitely a project car ill spend lots of hours on it.
