Everything posted by xXArchusXx
Starts; but let the key go to run position(dies)
I have to give mine gas when starting cold. revving to 2k rpm for 10 seconds should keep it alive. inspect the spark plugs and make sure you have spark.
1988 XT6 automatic how to refresh axles?
For dorman is there a part# for the silicone rubber boots? Can't find it.
Any good places that sell supplies and have decent warranty?
What stuff do i buy to refresh the axcles? its a fwd 88 XT6. do i have to pull them out of the tranny and drain the tranny fluid? new to this job.
XT6 1988 where is the flasher relay?
VID_20201010_123851.mp4
The pic is to the left of the brake pedal USDM. What else could it be? Unplugged each thing one at a time and the hazards still worked.
Did that. The hazards still turned on.
The lights turn on when u use turn signal doesn't flash and the hazards don't flash. It is 32 year old car after all. Where can I get a diagram for the fuses?
Where would that be?
The fuse box is just fuses and is fine. Underneath everything is just wiring. The ashtray thing has a blue box.
I have a 88 xt6 and don't know where the flasher relay is. What kind of relay do I buy? The hazards and turn signal lights turn on and stay on and don't flash and it screeches at you. Guessing it's under the dash. Has somebody done a tutorial?
Where is the flasher relay?
I have a 88 xt6 and don't know where the flasher relay is. What kind of flasher do I buy? The hazards and turn signals stay on and it screeches at you. Also the automatic seatbelts don't work for the drivers side.
Subaru XT na help!!
The passenger side kicks back with the tool. The drivers side is broken off.
Subaru XT na help!!
It comes out. There is a square knob.
Subaru XT na help!!
Subaru XT na help!!
That's what I have I don't see a hole.
Subaru XT na help!!
- Subaru XT na help!!
i took the seats out. where can i find the flasher for the fuse box in the repair manual i cant find it. there is a metal bracket hanging down on the passengers side whats that? is there a cabin filter?- Subaru XT na help!!
can i get new door switches and how do i know if they are bad? i found the tool but I couldnt find a hole anywhere.- Subaru XT na help!!
the seats are out and I found the tool in the bag but i cant find a hole to put the tool to move the automatic seatbelts on either side. where is the flasher relay? the two things in the picture fall out if you move them.- Subaru XT na help!!
the blend door hot to cold was one cable and had to take the center console up, there was a lot of sludge. it took 2hour. should the ebrake plate be diagonal? the top lights dont turn on when you press them. The drivers seat has a cable under it what does that go to? the windows take forever to move, and the passenger only moves with the engine on. the back seats should fold down right? What is the speed warning switch? where can i get a digital copy of the owners manual? iin cleaning the interior tomorrow.- Subaru XT H6 i have some things to fix please guide me.
the interior lights dont turn on at all even if you flick the switch, but the trunk light turns on tho.- Subaru XT na help!!
these were in the center console what are they? i also have the original key box but not the original keys or anything for the box.- Subaru XT H6 i have some things to fix please guide me.
thanks. its definitely a project car ill spend lots of hours on it. - Subaru XT na help!!
