Everything posted by squatty
'95 Impreza gauge cluster
squatty replied to squatty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you for the reply. My daughter's car is an automatic and the speedometer was still working. I wa actually able to find an Impreza cluster of the same year! I replaced it and the speedometer and odometer are both working. Now I just have to take it back out in the morning and figure out why half of the lights are not working.
The odometer in my daughter's '95 Impreza stopped working and I'm thinking I should try and replace the gauge cluster. I believe the legacy cluster will swap in fine and they are much easier to find in the junk yards. I've read through what I can find using the search but I was wondering if anyone has experience replacing an impreza cluster with a legacy cluster. I'll start by searching for the same year Legacys and Imprezas.
a/t flashes at start up
squatty replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, my mention of the duty C solenoid was probably premature. It sounds like it may be something else in the AWD.
squatty replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is not normal and someone here will fill you in on what it is trying to tell you. My guess is you may have some AWD torque bind problems (possibly a bad duty "C" solenoid?) Do you find you are having issues when making slow, tight turns? Does the car slow down and need more acceleration when turning in to a parking space, etc.?
Torque Bind - Sea Foam Trans Tune
So my son crashed and totaled my beautiful "92 Loyale with only 110,000 miles on it. After much back and forth with my wife I gave in and bought another car for my kids to use. I picked up a '95 Impreza with 125,000 miles on it. It has a 2.2 Liter motor with the 4EAT transmission. Of course after driving it a few days I realized it is experiencing torque bind. I believe it is the transfer clutch solenoid as the FWD fuse did not change a thing. (I will check the TCU codes next.) I plan on flushing/draining the transmission, adding an additive and seeing where that gets me first. The dealer wants $160 for a flush and refill so I thought I would do it myself. I've read so much about Sea Foam but have never heard mention of their transmission product Trans Tune. I was considering adding some prior to draining the transmission. Anyone have any experience with this product?
'94 Loyale EA82 losing coolant?
I don't want to steal your thread but I have a related question. When people say "overheated" how hot are we talking? I know my car ran hot after changing the coolant and having some air in the system but it never got as hot as the redline.
I'm in nearly the same boat. My '92 Loyale is doing the same thing. I'm pretty sure it is a head gasket. I recently changed and flushed my coolant. Shortly after I kept needing to add coolant and at first thought it was just air in the system. After adding nearly two gallons of 50/50 over a couple of months I have come to the realization it must be a head gasket. No leaks visible and I just found the smallest amount of foamy oil high up on the oil dipstick. I just couldn't believe the coincidence that the head gasket went right after I changed the coolant and so initially thought it was just air in the system.
92 Loyale Moral support Needed
I'll try to keep it short. I live on a private narrow lane. My car is parked on the lane and is usually fine. Neighbors constantly have bible study groups come and park in the lane. Twice now within a year my two Subarus have been backed in to by women (young teenage girls) leaving bible study group at night. Last time it was my 2006 Outback. Tonight it was my 1992 Loyale with 99,000 miles. I am very sad and frustrated. They will pay for repairs but I don't know that I can get it anything close to it's original splendor. Any advice or shared knowledge is appreciated. Thanks First picture is a Loyale (before) picture. Car is in driveway. At time of impact it was parked in front of my house in the lane you see. (Click to enlarge) These pictures were taken tonight after impact.
Brat Stolen!!!!!
I live in Wilsonville and drive a fire engine in Beaverton. I'll be looking for your ride.
I'm thinking about buying this Subaru.
http://portland.craigslist.org/mlt/car/461869969.html
92 Loyale 4wd Wagon Low Compression
If you have the time to wait, I would pass on that one. There are so many older Subarus on Craigslist in the PDX area to choose from. Also try Salem and Eugene Craigslist.
Got a "35" code: Purge Canister...
I had the same code and the CEL. I just got one from a junkyard for $15. I'll be putting it in soon and hope this takes care of the CEL...
13" - 14" Rims for winter tires
My '92 Loyale 4 wd has 185/70/13 tires on it's 13" 4 bolt rims. Looking through Craigslist I see tons of 185/70/14 and other such 14" winter tires and rims. Just wondering if there are 14" subaru rims with the 4 bolt setup or if I'm better off staying with the 13" rims.
2008 Diesel Legacy Outback
http://www.autobloggreen.com/2007/02/10/geneva-motor-show-preview-subaru-to-unveil-diesel-boxer-engine/
Where can I buy a Hitachi distributor for a Brat?
Thank you everyone...
Guess I'll have to start looking in the yellow pages and online, I know not this Foster u pull, CCR or GD...
I may be in a similar situation. Looking for a distributor for a 1992 Loyale. CEL keeps coming on and at one time the code said crank angle sensor but haven't checked the code in awhile...
My Coolant Leak
92 Loyale EA82 SPFI 87,000 miles The other morning I started my car to find the very noisy lifter sound for the first time. I didn't have time to do anything about it so I left for work using the high rpm to clean out the oil passage theory. The noise went away soon after. On the way home, I exited the freeway to see a small cloud of smoke coming out from under my hood. I checked under the hood when I got home to see I had sprung a coolant leak somewhere on the right hand (passenger) side of the engine. This same side has been experiencing a small oil leak for the past few months. There is no coolant anywhere on the top of the engine. The radiator hoses and the heater hoses all look good and any other small hoses I can trace look fine. The crossmember had a small puddle of coolant on it and the smoke seems like it was probably from coolant hitting the catalytic converter. The bottom right side of the engine looks as though I tried to wash off the leaking oil with coolant. The radiator is still topped off so I don't think I'm loosing a whole lot of coolant. I took the car for a test drive today and found I still get smoke off the catalytic converter after a drive. The car ran fine, good oil pressure and it did not overheat. When the car is running in the driveway I cannot see any active leaking anywhere. Between yesterday and today there are only a couple of small drops of coolant under the car. Does this sound like a gasket on the cooling jacket of the engine? Thanks...
EA-81 - Intermittent knock - what?!
I just tried the high rpm thing to rid myself of some lifter noise. Now I've got to track down a coolant leak!
Are you talking about noisy lifters? Maybe do a search and read some of those threads and compare their noise to your noise?
Kinky PCV Hose
Does my description make sense to anyone? Not a big deal?
Kinky PCV Hose
'92 Loyale EA82- Looking at my PCV hose, I see that just below the "T" junction the single hose coming up from below is held in place with a plastic holder. It then has to make a crazy bend forward over the holder to meet up with the junction and the other two hoses. Just wondering if this sounds familiar to anyone or if I should pursue trying to figure a way to lessen that crimp in the hose.
Bilstein Engine Flush?
Anyone ever try this engine flush? Or is seafoam the way to go... http://www.redwoodgeneral.com/flush.htm
Ebay - EA82?
After reading some of their feedback, looks like their shipping may be less than desireable?
Ebay - EA82?
I see they also have a turbo for $420...
