Search the Community
Showing results for tags 'H6 3.0'.
2002 H6 3.0 auto won't crank. For the last month when the car gets warm it would not start (just silence). Always started after sitting overnight. Now with the weather getting warm, after sitting for a day and a half its just silence apart from fuel pump and starter relay click, dash lights good. Tried a jump and still nothing. Narrowed it down to the inhibitor switch (in a MT this is called the neutral safety switch). Sits on the passenger side of the transmission and provides a short in P and N gear selections to allow the starter to crank. You can fool it into starting by shorting two pins together with a small paper clip. Connector is on top of the transmission just ahead of the firewall. T3/B12 pins 11-12. Looks like a new inhibitor switch is needed. Rear backup light also does not work and the dash gear shift position indicator lights are wonky. Problem is now my gear shift is locked I think because of my tinkering. I can unlock it by sticking a paper clip in the little hole to the right of the shifter...but what else is going on? I started the car with T3/B12 disconnected (despite a sudden electrical buzzing sound from underneath the car with the key in run position). Does the TCU get upset with B12 unmated and lock the shifter? How do I clear this? Reset the TCU/ECU or will it clear itself once the inhibitor switch is replaced and the car can start normally... code 852 is the neutral switch input circuit high
- 7 replies
- inhibitor switch
- H6 3.0
(and 4 more)
Tagged with:
Similarly to chrisw's issue at http://www.ultimatesubaru.org/forum/topic/140703-repair-the-engine-or-buy-another-car/, I am also not sure if I should repair/replace the engine in my 2001 H6 Outback, or just send it to scrap yard (as the dealer suggests). The car just died on me last weekend on my way back from a camping trip. It showed first "CHECK ENGINE" and then I noticed it started to overheat and eventually the engine shut donw. I did not expect this to happen, since my car has only about 130,000 km on it and I cared for it well for 12 years. The Toronto dealer shop (where I usually go to) told me basically the engine is gone - it caused the coolent system not to work properly due to some presure issue. I am not sure of all the details, but that is the gist of what I understood. He said it might be a head gasket, but he suspects that some other part of the engine was broken. I can drive the car fine for about 15 minutes, before I need to stop and let it cool. Has anyone heard of this H6 3.0L engine issue? From what I've been reading these engines should last longer than the 2.5 (H4) engines - since they should not have that many head gasket issues. I allso looked at the used H6 refurbished on http://www.ccrengines.com/, and see they are not cheap (over $6000). This, plus shipping to Canada, makes my feel such a repair is definitely not worh the car's value - assuming it is in good running order (which is not more than $5000). If anyone of you know of good independent mechanic in Toronto (Canada) area who could give me a second opinion, I would be very greatfull. Thanks
