September 15, 200916 yr I'm trying to get a keyless entry to work. It has the subaru keyless entry box under the dash secured by zip ties. I tried holding down the programming button but nothing happened. I held it down for like a minute with the door opened and the key in the "on" position. I also verified that there is a 20 amp fuse installed for the keyless entry. Fuse is in good shape. any recommendations are appreciated. Thanks
September 15, 200916 yr the cars101.com site has lots of Subaru specific keyless information I believe, that's how I do all of mine.
September 15, 200916 yr I'm trying to get a keyless entry to work. It has the subaru keyless entry box under the dash secured by zip ties. I tried holding down the programming button but nothing happened. I held it down for like a minute with the door opened and the key in the "on" position. I also verified that there is a 20 amp fuse installed for the keyless entry. Fuse is in good shape. any recommendations are appreciated. Thanks i just did this over the weekend. the first time i tried i had the car in on position, radio worked, windows didn't. the next time i had in in the run position (but never cranked it over) this way worked just like cars101 said. did you try it that way?
September 25, 200916 yr Author I just tried it again with the door open, in the run position. Just like car101 says to do. nothing happened, no door lock cycling. I know the button works, cause I disconnected the battery and it squawked at me until I pressed the button in the run position as directed by cars101. any idea how to diagnose if the keyless entry box is working and/or connected properly?
