hebrewhammer Posted September 26, 2009 Share Posted September 26, 2009 95 impreza ej18 5mt awd car feels very on/off ish when it comes to accelerating and decelerating. there is no mid point it seems. think the throttle cable is too tight? or any other ideas? thanx in advance. Quote Link to comment Share on other sites More sharing options...
lmdew Posted September 26, 2009 Share Posted September 26, 2009 Does it idle OK? Did you check the TPS with a meter to see if its within specifications and there are no opens? Check the vac hoses as well Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 26, 2009 Share Posted September 26, 2009 throttle could be sticking, clean the plate. tune up - plugs, wires? any check engine light? bad TPS. Quote Link to comment Share on other sites More sharing options...
hebrewhammer Posted September 26, 2009 Author Share Posted September 26, 2009 newish plugs. no CEL. it idles perfectly. could anyone explainthe process to check the TPS? Quote Link to comment Share on other sites More sharing options...
hebrewhammer Posted September 26, 2009 Author Share Posted September 26, 2009 It is also kinda surgy in the lower end of the rpm spectrum. got a multi-meter. can i check if the wires are good also. anyone care to explain the process or atleast tell me what i'm looking for. thanx! Quote Link to comment Share on other sites More sharing options...
