Finally a subie to lift
I've owned 3 subaru's and have been wanting to lift every one of them. Now I'm on my 4h Subaru and I want to lift it.
I don't want to get a suspension lift mainly because i dont want to go through cv-axles. I mainly have one question. How good is a body lift? and How easy is it neccessarly to make and install? Also, if i do a body lift do i still need to do an alignment adjustment? ok thats more than 1 question :-P
is it neccessarly as easy as bolting in spacers like here:
http://ultimatesubaru.org/forum/showthread.php?t=102498&highlight=lift
I'm on a rather /tight/ budget but, i have access to a welder and some steel. I was thinking 2 - 3".
Oh By the way I'm working on a '88 GL, EA82 Wagon.
Edited by crazyman03
wrong title
you need to search the offroad forum...........
it relatively easy.with a 2" lift on those wagons there a re very little issues.have wheeled with several that have had no issues that the ea81 possess's.......look, search,m read.offroad.cheers,brian
You wont go through Axles and you will not need an alignment, all it does is shove your tires down 2". It takes me about 2 hours to put the whole thing on, and Yes it is as easy as bolting it up just like that, that is a 2" lift, 3" you have to drop all the crossmembers and that is a far more involved deal..................
Jeff
Edited by one eye
Read this whole thread..................
http://www.ultimatesubaru.org/forum/showthread.php?t=94629&highlight=marcus56
Jeff
