3 minor assembly questions
putting the finishing touches on an assembly and it's been so long since i started that i forgot a few things . i can't recall where each of these brackets went and where the vacuum hoses from the green fitting on the front go to .
thanks for your help . jim . HPIM0678.jpg[/img][/img]
I can't contribute much except to say that I have seen that valve in that location before. It was on a parts car I had for just a short while. I have always wondered about it. I just thought it was part of the block heater.
'81 explains it - they didn't offer power steering till '82 and that valve and it's associated vacuum lines would interfere with the EA81 power steering belt. That valve was probably moved to the manifold.
