bigo1966 Posted October 7, 2009 Share Posted October 7, 2009 So im in the process of hooking up the ST engine to the EA-82 transmission. Im trying to figure out if I should ridigly mount the trans and engine or have them on rubber motor mounts.. i.e. rebuild the trans mount so they are solid and the new motor mounts so they are solid. Or use some existing motor mounts that I have in the garage to isolate the engine from frame/car and ridigly fix the ST engine to the trans. Keep in mind that its baslically a divorced setup but my adaper shaft does not have any u-joints. Splines from ST output shaft basically welded to the splined shaft in the center of the subaru clutch. I hope you can follow that and i really need some input. Orion Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 7, 2009 Share Posted October 7, 2009 my white wheeler is solid steel mts no rubber , it has no issues I would go solid Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted October 7, 2009 Author Share Posted October 7, 2009 How are the vibrations in the car? Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 7, 2009 Share Posted October 7, 2009 How are the vibrations in the car? not noticable that bike engine was rigid mounted in the bike right? Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 7, 2009 Share Posted October 7, 2009 why not solid mount the tranny, and rubber mount the motor? i know it sounds odd, but the little vibration from the motor would be taken up from front rubber mounts, and the tranny-engine union would benefit from the solid trans mounts....... make sense?cheers, brain Quote Link to comment Share on other sites More sharing options...
Crawler 65 Posted October 7, 2009 Share Posted October 7, 2009 why not solid mount the tranny, and rubber mount the motor? i know it sounds odd, but the little vibration from the motor would be taken up from front rubber mounts, and the tranny-engine union would benefit from the solid trans mounts....... make sense?cheers, brain Every time I have tried to solid mount 1 and soft mount the other it has ended in disaster:-\ I don't recommend it at all. I have seen it bust trans cases, crack bell housings, twist drive shafts, snap motor mounts, ect. Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 7, 2009 Share Posted October 7, 2009 well, at that point it would be the torque from the engine ...so just switch them around. it is a motorcycle engine,mated to a subie trans.all of the torque will be with the motor. yep, i say solid mount the engine, soft mount the trans. who knows.might work.cheers, brian Every time I have tried to solid mount 1 and soft mount the other it has ended in disaster:-\ I don't recommend it at all. I have seen it bust trans cases, crack bell housings, twist drive shafts, snap motor mounts, ect. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted October 7, 2009 Share Posted October 7, 2009 I would rigid-mount the motorcycle motor to the Subie trans, then use solid trans mounts and rubber motor mounts. On the EA82 trans crossmembers there are already a pair of rubber bushings where the x member bolts to the body, IN ADDITION to the rubber trans mounts. The other way to go would be mount the crossmember rigid, then use rubber mounts on the tranny and motor. Either way, you have to build some kind of structure to tie the motor and trans together rigidly, otherwise you will blow up that adapter shaft or a trans bearing or a main bearing on the motor, unless you make a new shaft that has some kind of joint in it. I see things just like this every day where I work, and I know exactly what can happen if its not done right.... -Bill Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted October 8, 2009 Author Share Posted October 8, 2009 Here is the plan. Ridgedly(is that a woard??) mount transmission to engine and have engine sit on another set of stock engine mounts. From what ive gathered the trans to frame and engine to frame have to be the same material, engine to trans ridged. Thanks everyone. Quote Link to comment Share on other sites More sharing options...
