Arthrogrian19 Posted November 10, 2009 Share Posted November 10, 2009 Hey guys, I have a special situation where I need to modify the shifter on my '91 Loyale (5mt push-button 4wd) due to a physical disability. I need to extend the shifter up approx 9" and back approx 6". In doing so, I fear the shift throw will be super long. So, I'd like to install a Kartboy short shifter to decrease the throw. I asked Tom @ Kartboy to see if their shifter will work with the 5mt, but he needs a pic or two to confirm that it'll work/fit. Does anyone have pics of the shifter without the boot?? TIA! Ian Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 10, 2009 Share Posted November 10, 2009 The shifter on the push-button 4WD is a bit different than those used on the EJ series transmissions. The 4WD shift assembly uses a "shelf" that contains the pivot point for the shifter as well as the D/R shift lever for the older non-pushbutton style transmissions. If I were you, and wanted to use the kart-boy stuff, I would probably just switch over to the entire EJ shift linkage system. You would have to mount the rubber "sling" for the pivot rod but that wouldn't take a lot of fab work. Being that you don't need the shelf to mount the D/R lever to it shouldn't be that big of a deal. GD Quote Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted November 11, 2009 Author Share Posted November 11, 2009 Thanks for the reply! Very helpful! I think I'll go ahead with the shifter extension and maybe convert to the EJ linkage and Kartboy shifter later, after I get used to the car. Thanks again! Ian Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 11, 2009 Share Posted November 11, 2009 Are you the same guy that is on Subaruforester.org? Quote Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted November 12, 2009 Author Share Posted November 12, 2009 Are you the same guy that is on Subaruforester.org? Yep! http://www.subaruforester.org/vbulletin/f100/so-i-bought-loyale-61255/ Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 12, 2009 Share Posted November 12, 2009 Cool, keep us updated on the project!! Quote Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted November 12, 2009 Author Share Posted November 12, 2009 Cool, keep us updated on the project!! I definitely will! I'm talking to a vendor on Nasioc to have a special extension made to my specs... I just need to find the time to take all of the measurements and tie up loose ends, so I can take the car home. The laundry list is: Shifter Extension Shift Knob Shift Boot (maybe) Relocate 4WD button to dash using the cruise control button. Install tilt steering column and swap ignitions. Thoroughly clean the car and enjoy! After the shifter extension is figured out the rest should be cake. I might install some Hella 500s while I'm at it! Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 12, 2009 Share Posted November 12, 2009 Nice!! Can't wait to see it come along. Quote Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted November 15, 2009 Author Share Posted November 15, 2009 I'm getting some fantastic help from a vendor on NASION called WC Lathe Werks, who makes custom knobs and shifter extensions. I put together a rendering of the shifter and knob. I can't wait to drive this car! Should be just in time for the Hatch Patrol Christmas Tree Run. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 15, 2009 Share Posted November 15, 2009 Nice!!! You still gotta get a dual range for it though!!!! Quote Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted November 15, 2009 Author Share Posted November 15, 2009 Nice!!! You still gotta get a dual range for it though!!!! There's one sitting in my mechanic's shop that we might put in...just waiting for this tranny to die. lol Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 15, 2009 Share Posted November 15, 2009 There's one sitting in my mechanic's shop that we might put in...just waiting for this tranny to die. lol Sweet!! If you are gonna off road it, you won't believe the difference!! Quote Link to comment Share on other sites More sharing options...
Arthrogrian19 Posted November 17, 2009 Author Share Posted November 17, 2009 Shifter p0nr! Quote Link to comment Share on other sites More sharing options...
