Engine swap question?
Can I take a 2.2 automatic from 91-94 legacy and drop it in a 96 outback automatic? I had planned on removing the original 2.2 intake manifold and replace with a 2.2 intake manifold with an EGR to the 91-94 2.2. Any problems that anyone can foresee with this?
I think the speedo sensors are different. The 90-94 has a cable, the 96 has an electronic speed sensor.
I've put the electronic speed sensor on to the older trans and it works, but I don't know if it would work the other way.
Gear Ratios may be different as well so match the rear diff.
Let me clarify...I want to take the 2.2 engine from a 91-94 legacy and install it into a 96 outback that has a bad 2.5 with an automatic trans.
I heard I should just be able to switch the intake from a 95 2.2 with an egr onto the 2.2 engine from a 91-94 legacy. Any sensors or anthing else I need to mess with?
I don't think you eve have to do that. This has been discussed many times here. The search function is your friend.
I appreciate the response fairtax4me. I did search and couldn't find what I was looking for.
The EGR was the main concern. I didn't think the 90-94's had one and it seems that if I install a 95 2.2 intake with an EGR on the 90-92 without an EGR, it should plug and play into the 96 outback automatic with a bad 2.5.
Can anyone confirm?
The car is sitting right now waiting for an engine.
:banana:
if the engine itself doesn't have EGR you're going to have issues. The EGR is not just an intake manifold related item - it is plumbed into the long block (the head), so the engine needs to have EGR if you want a simple plug and play swap.
You can work around it a few different ways, none of which are simple (define simple?!?!!).
Got it now.
Thanks
