paulpicard Posted November 12, 2009 Share Posted November 12, 2009 My 92 Loyale S/W has apparently developed a water leak that results in a half-cup of water (NOT coolant) spilling onto my left foot when I back out of the drive after a rainy or snowy night. Assuming a leak originating at the cowl, I see what appears to be drain holes punched into either corner of the cowl, but not sure if they are, or could the wiper pivot shaft be a source ? :-\ All suggestions as to what to look for are welcome and appreciated! Quote Link to comment Share on other sites More sharing options...
Dirk Posted November 12, 2009 Share Posted November 12, 2009 My Windscreen leaks in both bottom corners and produces the same results. Been meaning to fix it for a while now. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 12, 2009 Share Posted November 12, 2009 Take a garden hose to the cowl and make sure the water drains out. You should see it trickling out of the side body drains at the cowl. They may be clogged, so unclog them. No drilling new holes though. nipper Quote Link to comment Share on other sites More sharing options...
paulpicard Posted November 12, 2009 Author Share Posted November 12, 2009 Thanks to both - the w/s was replaced this spring, so it might not have been sealed correctly. Nipper, I assume there ARE drain tubes connected to those holes at the cowl ends? Because the one on the driver's side next to the wiper pivot was obscured by mud and I only noticed it when I wiped the area clean. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 12, 2009 Share Posted November 12, 2009 Are you talking about the holes at either end of the cowel that empty out into the fenders? There is a drain hose for the HVAC Quote Link to comment Share on other sites More sharing options...
paulpicard Posted November 12, 2009 Author Share Posted November 12, 2009 Are you talking about the holes at either end of the cowel that empty out into the fenders? Yes I am. The car does not have A/C, and the water is not a coolant leak. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 12, 2009 Share Posted November 12, 2009 Yes I am. The car does not have A/C, and the water is not a coolant leak. They just drain into the fenders. They shold be open. Also look under your doors, you will see drainn holes there too that shold be open. They get clogged with leaves. nipper Quote Link to comment Share on other sites More sharing options...
paulpicard Posted November 12, 2009 Author Share Posted November 12, 2009 Thanks, nipper. I think the wiper shaft might be the source, if those cowl drains simply go to the fender. Anyone else had a problem with that? Quote Link to comment Share on other sites More sharing options...
gadberry Posted November 13, 2009 Share Posted November 13, 2009 yes, I have the wet drivers side floorboard issue... I have an 1981 Wagon. i've not tracked down the source of the leak yet, and although I doesn't smell like coolant....it feels kinda oily... However, I don't believe it's the heater coil since it only appears after a rain.. and I think the sound-dampening fabric material may contribute to the funk and the oily feel to the 1/8 cup of liquid that accumulates after a rain. I've not removed the cowl cover yet to check those drain holes that often clog... but I can see what appears to be a drain in the outside corners of the cowl (and at the top of the door jamb; under the corner of the window). Someone should take a pic of these drain locations; particularly at the bottom of the door.. is that in the middle of the door, or in the bottom corners, or... Question: Can anyone explain how to properly remove the wiper arms, without breaking them? I've tried prying them up and off their shafts but I'm afraid I'm about the snap'em off when I do... Can't remove the Cowl Cover without those puppies coming off... this is why I've not checked for the clogged drain holes.. thanks in advance! gadberry Quote Link to comment Share on other sites More sharing options...
nipper Posted November 13, 2009 Share Posted November 13, 2009 The door has three or four drain holes. Lie on your back and look up they are obvious. nipper Quote Link to comment Share on other sites More sharing options...
