water pump
There is a little square rubber gasket in the kit I cannot figure out where this goes. Anyone know?
Between the water pump and the timing belt cover IIRC. There's likely a groove in the water pump housing for it if I'm not mistaken.
Thanks GD. So If I have no cover I do not need it?
I have never used them even with cover's so I'm pretty sure you'll do just fine. I have run all mine without cover's as well and generally throw that thing away. The belts last such a short time that it's not worth trying to protect them - 50k and you'll be back in to clean and replace belts anyway......
Thanks that was what I thought. I did not see one when I removed so was a little curious as to where it went. HAve a great evening. Got to run to the part store to get something else. Almost got my subie back to normal.
