peewee Posted December 7, 2009 Share Posted December 7, 2009 I have a grinding sound coming from the front // replaced both CV axles along with wheel bearings, is seems to only do this when cold, if i drive it for 10miles or til it get warm the grinding sound stops please help thanks Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2009 Share Posted December 7, 2009 Worn cone washers/hubs or loose lug nuts would be my guess without seeing it. GD Quote Link to comment Share on other sites More sharing options...
Frank B Posted December 7, 2009 Share Posted December 7, 2009 And this hasn't changed at all after you've replaced all those parts? Go through the brakes. Clean all the grease, sand, and other funk from everything on the front end. Then clean and bleed the calipers, replace pads, scuff the discs with emory cloth(or have them turned) and check the shields to see if anything is rubbing the discs. Quote Link to comment Share on other sites More sharing options...
ettev Posted December 7, 2009 Share Posted December 7, 2009 go through the brakes. Clean all the grease, sand, and other funk from everything on the front end. Then clean and bleed the calipers, replace pads, scuff the discs with emory cloth(or have them turned) and check the shields to see if anything is rubbing the discs. +1 Quote Link to comment Share on other sites More sharing options...
peewee Posted December 9, 2009 Author Share Posted December 9, 2009 Thanks all , I will replace the cone washers this weekend keep you all updated Quote Link to comment Share on other sites More sharing options...
peewee Posted December 14, 2009 Author Share Posted December 14, 2009 Okay All this weekend I replaced the Cone Washers on both side (they looked bad) also made trip to local junkyard and snagged two hubs ... after install and short test run all is fine no grinding.. GOT TO LOVE THE BRAT !!!!!! thanks all Quote Link to comment Share on other sites More sharing options...
