January 12, 201016 yr I am replacing the front pads and rotors on my 1984 GL 4WD wagon. I am following the instructions in How To Keep Your 72 thru 84 Subaru Alive, by Larry Owens. The instructions call for "PBC" grease to lubricate the pad springs, and "Silicone" grease to lubricate the pivot pin. I could not find these products at my local auto parts store. I have Master Pro Hi-Temp Disc Brake Wheel Bearing grease, NLGI No. 2 and Multi Purpose Lithium Grease Are these sorts of grease an acceptable substitute for the PBC and Silicone grease? mkoch
January 12, 201016 yr When you say PBC you're not mistaking it for this are you? Silicon grease would just be the dry silicon spray? I'm not sure bro, still have much to learn about brakes. Hopefully GD or one of the other guys can set you straight. Good Luck.
January 13, 201016 yr the pbc stuff would be the little 99 c packs of brake quiet anti squeal stuff. the silicone can be found in the same 99 c packs, or if you go to napa, look for 'syl-glide' brand
January 15, 201016 yr use this http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_CALIPER-LUBE-Permatex_12027858-P_N3223_T/GRP2008?cm_mmc=CSE-_-Shopping-_-VALUE3-_-VALUE4&srccode=cii_13736960&cpncode=19-34717556-2 on the sliders. works like magic. Cost's about 10bucks though
