January 19, 201016 yr Driving down the street and all of a sudden I hear this sudden constant rattling under the hood. Open the hood and the radiator fan isn't spinning and is shaking violently. I turn off the engine and inspect the belts which seem fine, but the radiator fan is just hanging loose. Whats the scoop?
January 20, 201016 yr Author I called and got a quote for a new water pump and thermostat. The shop I contacted quoted me $350-400 dollars. Does that seem a little steep?
January 20, 201016 yr I called and got a quote for a new water pump and thermostat. The shop I contacted quoted me $350-400 dollars. Does that seem a little steep? SOunds right considering you have to remove the timing belts to change the water pump.
January 20, 201016 yr You should have the timing belts done at the same time as the labor is the same. Belt and tensioner sets can be had on ebay for $75 or less. Do the labor yourself and you can have it done for under $100. GD
