March 17, 201016 yr Gas mileage dropped about 2 miles per gallon after having ATF changed on 2008 Outback 2.5i. Any idea why?
March 17, 201016 yr Author Subaru requires at 30,000. 41,000 at this time. Been trying to figure this out for a while.
March 18, 201016 yr Did you use the proper fluid? How did you determine the MPG number? May just be a coincidence as 2mpg is hard to say is anything big. A slight change in driving habits can do 2-5 mpg difference. Check tire pressures. nipper
March 19, 201016 yr Author Had to start filling up about 35 miles sooner per tank was first clue. I also keep mileage records and use the dash readout. They ordered Subaru ATF.
