Sudden gas mileage drop
Gas mileage dropped about 2 miles per gallon after having ATF changed on 2008 Outback 2.5i. Any idea why?
Subaru requires at 30,000. 41,000 at this time. Been trying to figure this out for a while.
Did you use the proper fluid?
How did you determine the MPG number?
May just be a coincidence as 2mpg is hard to say is anything big. A slight change in driving habits can do 2-5 mpg difference.
Check tire pressures.
nipper
Had to start filling up about 35 miles sooner per tank was first clue. I also keep mileage records and use the dash readout.
They ordered Subaru ATF.
