April 7, 201016 yr so i have two engines, an ej18 from a 1994 impreza that needs rings done at least. the other engine is an ej22 source unknown but i can find out. this engine has been overheated and blown the head gaskets at least. so i have to rebuild one of them or make a solid engine out of the two. i havent pulled either engine apart yet to check the actual condition of the internals, but assuming both need some extent of rebuild what would the best head/block/everything else combo i could go with to make the most power? and where the hell do i get parts like rings, bearings, engine internals, etc?
April 7, 201016 yr I don't believe that there is any performance gain swapping EJ18 parts onto an EJ22. Stick with the EJ22, its bigger, has more power and is bullet proof if you don't overheat it. As far as finding Subaru parts Linky
April 8, 201015 yr It was meant in good fun There are a few online subaru parts stores, a few are good, a few are bad. In Seattle, Carter isn't bad, and the online parts from Walker's is pretty good.
