'98 Outback Legacy Limited Theft Deterent System Alarms
I have a problem with the Alarm going off for no appearant reason (maybe dead battery). How do I reset this alarm to shut it off?
typically there is a push button under the dash used to reset the alarm, press and hold. maybe with the key in the acc position.
i have a 97 obw that does a similar thing, but i'm pretty sure it is "programmed" to the same remote as my neighbors. i cut the wire going to the alarm horn, now the lights just flash.
do you have a remote for it? i think that will 'clear ' the alarm as well. if you do not have a remote, getting one and programming it to unlock your car may help. it will change the frequency the system responds to.
www.cars101.com has instructions how to reset it.
nipper
