3.3 swap questions
so if i were going to try to swap my svx motor 3.3 h6 into my 96 impreza ouback
would i be able to at all?
could i use my 5 speed Tranny?
ECU swap?
Different engine harness?
I've seen it mentioned here, but have not searched for the info in depth. I'm sure one of the members here will give you a heads up. I'll check back because I'd like to see what's involved with this swap:banana:
trans will bolt right up.
the wiring and ECU will all be custom wiring, splicing, and installing. not for the faint of heart. it's a huge job in those terms.
