June 4, 201015 yr I`m replaceing all the seals befor I put the engine back in the car. I understand there is a O ring with the seal on the oil pump shaft. Can the O ring be replaced from the from the seal side? or does the shaft have to be pulled from the inside, oil pan? If so is it nessary to replace? I`m haveing my Nissan mec. change everything out for me I`m just getting all the information befor I order all the parts. It`s a 2001 forester. Thanks, Roger Edited June 4, 201015 yr by Roger Stokes wrong one
June 4, 201015 yr Author I`m replaceing all the seals befor I put the engine back in the car. I understand there is a O ring with the seal on the oil pump shaft. Can the O ring be replaced from the from the seal side? or does the shaft have to be pulled from the inside, oil pan? If so is it nessary to replace? I`m haveing my Nissan mec. change everything out for me I`m just getting all the information befor I order all the parts. It`s a 2001 forester Thanks, Roger
June 4, 201015 yr The O-ring is on the lower part of the block behind the oil pump....Check out the Beer Garage....worked for me. GL, Td Edited June 4, 201015 yr by wtdash clarify location
June 4, 201015 yr Its the blue O-ring in this picture. Need to remove the Oil Pump first. Will make it easier to change the front crankshaft seal too.
