June 23, 201015 yr Here is a cheap-o fix for leaky widows. 1. Clean the gasket and window contact area w/ acetone or paint thinnner. A bondo spreader works great for cleaning the crevase between the window and the gasket. 2. Take a tube of permatex black gasket sealant, and drill out the end tip of the tube nose cone. 3. Using the bondo spreader to create a gap between the gasket and glass, stick the nose cone of the permatex down in there and squeeze a bead along that line. 4. press the gasket back in place, and wipe off excess that squeezes out. If you have the extra $ for replacement gaskets(or can even find them) this may not be the best solution for you. It worked for me
June 24, 201015 yr You can get anything on Subarupartsforyou.com Genuine parts, and pretty much every and any part you can think of. I have done the permatex trick in the past, works good enough for my taste. -Tom
