losingalltouch Posted June 25, 2010 Share Posted June 25, 2010 (edited) I've put close to 500 miles on my 86' GL-10 Turbo after an engine swap including a new clutch. I've had this continual odd noise from the clutch that happen whenever I shift gears and release the pedal too fast, or when I ride gears ( 2nd gear at 20mph, for example). Haven't heard this in 4th or 5th gear at all. Didn't have this problem before the engine swap, either. The noise kind of sounds like a quick "cough" or metal-against-file kind of noise. This only happens when I'm not accelerating. The clutch is adjusted so that it releases a few inches from the floor (this is what I read to do for a new clutch). I don't have this problem when I release the clutch pedal slowly, so that's what I've been doing lately. It still happens when I ride gears, especially downhill. Could this just be the noise of the clutch wearing in? Should I tighten/loosen the clutch? I checked all the engine-to transmission bolts and they're fine. Haven't checked the pitching stopper rod but it seems tight. Thanks Edited July 4, 2010 by losingalltouch Link to comment Share on other sites More sharing options...
losingalltouch Posted June 28, 2010 Author Share Posted June 28, 2010 Bumping this... Really need some help!! I'll try to post a video. Link to comment Share on other sites More sharing options...
losingalltouch Posted July 9, 2010 Author Share Posted July 9, 2010 Alright, last bump! I'm going to put this car out of it's misery in a couple months anyway. Wish it were something simple, but i get the feeling it's not. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2010 Share Posted July 9, 2010 Sounds like a syncro problem but it's hard to tell fom your description. GD Link to comment Share on other sites More sharing options...
