June 26, 201015 yr Hi Guys Well i tried to find my old Post and well i couldn't find it. so here i am starting a new one. I'm in the process of Restoring my 92 Loyale. Specs: 1.8L SPFI H4 1992 Wagon 3 Speed Automatic First off i'm Restoring the Badly Rusted Body. when i first got my 92 Loyale (April 30th 2005): When it had it on the road: More Info as i go along
June 27, 201015 yr Author Ordered the Rust Repair Panels from JC Whitney. L & R Wheel Arches. ($120) My First Restoration. so i am new to this and will be asking for help from the guys that know about Restoration.
June 27, 201015 yr Author Engine Bay clean up: Also Cleaned up some Rust. now this is pretty much surface rust. i need to clean that up so i can POR it later on. the rust repair panels ordered will take car of these Areas: Edited June 27, 201015 yr by SubaruJawn
June 28, 201015 yr Author any suggestions on cleaning up the surface rust under the body ? found this but dunno if its any good. http://paint-and-supplies.hardwarestore.com/50-278-rust-removers-strippers/naval-jelly-rust-dissolver-610532.aspx -Jawn
June 29, 201015 yr You would be better of going with this. http://paint-and-supplies.hardwarestore.com/50-278-rust-removers-strippers/rust-oleum-rust-reformer-266080.aspx
June 29, 201015 yr Author You would be better of going with this. http://paint-and-supplies.hardwarestore.com/50-278-rust-removers-strippers/rust-oleum-rust-reformer-266080.aspx you gave me the link for this. i wanted to see what else would be recommended. 8ozes i don't think is enough hopefully they have it in larger container.
July 13, 201015 yr you got to get rid of that 3eat there slooooowwwww , but the car is still awsome ,
July 14, 201015 yr Author you got to get rid of that 3eat there slooooowwwww , but the car is still awesome , oh defiantly. but there's no 4EAT for loyal. unless i use 1 from a turbo and its Electronic Shift. i say Fuq that after the trouble i had with my 91 legacy.
November 18, 201015 yr Author i haven't laied a tool on her for several months now. all i did was move her across the field once more Pics: I did find 2 Loyale's near by for parts, but i have no Money to buy them
November 19, 201015 yr oh defiantly. but there's no 4EAT for loyal.unless i use 1 from a turbo and its Electronic Shift. i say Fuq that after the trouble i had with my 91 legacy. Thats why you get a 5 spd d/r=)
October 28, 201114 yr Author Ordered the Rust Repair Panels (Mill Supply not JCWhitney) going to use the rocker support from xt6 if its any good. Edited November 1, 201114 yr by SubaruJawn
November 1, 201114 yr Author gonna take abotu a month my rust repair panels come in. I used Scubert to Pull Subie out of the Yard. (big bro pulls little sister :-p) After/during Restoration, rust proofing/resisting will be applied. found 2 Loyale's for Parts. well one is a GL. trying to buy both for parts. (both Manual Trans) after reconstruction of the Rocker i'd like to fill it with that foam stuff that hardens and gives the car strength. what was that stuff called ?. Edited November 1, 201114 yr by SubaruJawn
