jboymechanic Posted July 25, 2010 Share Posted July 25, 2010 As you may or may not know, I recently purchased a '87 GL-10 Wagon. I'm getting it road worthy and it's getting closer every day, and now that I have driven it on a road I've noticed some clicking from the front end. I can only hear it at lower speeds, I'm assuming at least one of my axles needs repairs. Is this a solid assumption? Can these axles be rebuilt? Where can I source a rebuilt kit or purchase good quality new axles? Link to comment Share on other sites More sharing options...
jboymechanic Posted July 25, 2010 Author Share Posted July 25, 2010 In case it matters, this was an automatic car converted to 5 speed manual with dual range. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 25, 2010 Share Posted July 25, 2010 Could be the axles - especially if it's clicking on turns and you see blown out axle boots. Replaceing the axles is much easier than rebuilding them. Chances are good that you don't have the facilities to properly rebuild a drive axle and in any case a reman is cheaper than the individual joint components. I use the EMPI's - I get them at a local import parts house - they do a lot of EMPI VW parts and they also carry their axle line for all makes/models. Subaru axles run about $69 each. GD Link to comment Share on other sites More sharing options...
jboymechanic Posted July 25, 2010 Author Share Posted July 25, 2010 I was able to find the EMPI axles online, but how do I know if I have 23 or 25 spline axles? Again, it has a 5 speed manual trans with dual range swapped in place of the original automatic.:-\ Link to comment Share on other sites More sharing options...
jboymechanic Posted July 25, 2010 Author Share Posted July 25, 2010 I'm hoping I don't have to pull the axle just to find out. I will be replacing engine and trans mounts at the same time. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 25, 2010 Share Posted July 25, 2010 Probably 23 but if it came from a turbo it would be a 25 spline transmission. Those are rare though - D/R turbo 5 speeds are not a common thing to have on hand and not know about it. It would have a 3.7:1 rear diff and a 1.2:1 low range if it's a turbo tranny. 3.9:1 and 1.59:1 if it's a non-turbo (likely). GD Link to comment Share on other sites More sharing options...
idosubaru Posted July 25, 2010 Share Posted July 25, 2010 MWE also sells top notch Subaru axles out of Colorado. Great guy to deal with. Link to comment Share on other sites More sharing options...
jboymechanic Posted July 25, 2010 Author Share Posted July 25, 2010 The rear diff says it's a 3.9 gear ratio and I slipped the axle off the trans part way this morning and counted 23, so you know your stuff. Thank you. Link to comment Share on other sites More sharing options...
