September 2, 201015 yr I just bought a 92 loyale wagon m/t with 233,xxx miles. Did a tune up last nite and was wondering where the fuel filter is located? How do I check the CEL? Thanks
September 2, 201015 yr The fuel filter is up against the firewall on the driver's side. Get yourself a cheap manual, or a factory service manual. They really come in handy, even for basic stuff.
September 2, 201015 yr Author alright thanks. I followed the fuel lines to the firewall but didn't see it. The glovebox came empty, so I do need to get an owners manual. But untill then I'll also be reading and trying to learn things on here as well.
September 2, 201015 yr the fuel filter is next to the windshield wiper motor. in the engine bay, left side of the car, up by the windshield. its cylindrical. get a manual, youll need it. oh ya welcome aboard RV
September 2, 201015 yr Author thanks! this is a great MB, how do i check the check engine light? what do most motors with compariable milleage read the oil psi at? 45 normal? and is the temp gauge normally close to the bottom of the scale?
September 2, 201015 yr the lower the temp the better on these things. make sure it doesnt go too high. overheat=warped heads=$$$$$. not sure about CEL, never had to check mine(91 loyale wag).
September 2, 201015 yr Author alright the temp gauge never goes too high but the engine seems pretty warm when i pop the hood. guess ill find out if its not reading right tho. changed the spark plugs last nite and they were stock! 233,xxx miles
September 2, 201015 yr I was surprised at where the temp sits on my 93 Loyale. I had an 87 GL, and I have an 83 Toyota pickup, and both those tend to sit right below half-way on the gauge. But my Loyale sits just above the bottom. If you traced the fuel lines there you should have found it...unless someone took it out for some reason. It's in a clip right up against the firewall, up top by the windshield as was already mentioned. Right up on top. I haven't had to read codes yet.
September 2, 201015 yr Buy a Haynes repair manual and it will explain the CEL code reading procedure. It will involve removing a plastic panel on your dash below the steering wheel where you will find a blinking light. The service manual will give more details, but you will have to count the total number of long and short blinks of the light (I'm not sure which blinks go first, long or short). For example, 4 long blinks and 6 short blinks would be CEL code 46. You'd then look that code up in the service manual and go from there.
September 7, 201015 yr Author yea i knew about the light blinking, didn't know if it was a trick like turning the key on, off and back on or something like that. And yea I did the fuel filter after being told about where it was and yea they bypassed the fuel filter and put a small copper tube instead.
September 8, 201015 yr Yea.. I have a 92 Loyale also. I have done so many things to the car (including cylinder heads) and the Temp gauge still sits on the bottom of the scale. I will even have the electric fan kick on at stop lights but the gauge is still on "C" I just Don't worry about it anymore. and for the CEL... you have to have a manual.. but it says that the plug in connections (for the base timing mode, and to access the stored ETC's) are under the dash... Mine are under the hood behind the fuel filter that you don't have, against the firewall. they are Green and Grey (or beige...or something) . Then you can see the blinking light of the ECM under the steering column and above the plastic kick panel. You dont have to take the kick panel off.. just look between them... Count your blinks and put a piece of electrical tape over the CEL. I have a bad VSS.(vehicle speed sensor) that I really dont care about... ENJOY
September 19, 201015 yr what do you guys mean by connect the wires? trying to read codes on a 90 2wd loyale.
