September 5, 201015 yr I've seen a couple of guys on youtube ( ) trucking through a mudholes on mount walker and i was just wondering what's the minimum tire size you recommend for that trail?
September 5, 201015 yr I've got AT 27's and haven't seen any smaller than that up there. No stuckage yet, but weather could change that easily. Having a welded diff is equally important! Here's mine...one of the funnier vids up there:
September 5, 201015 yr Author I've got AT 27's and haven't seen any smaller than that up there. No stuckage yet, but weather could change that easily. Having a welded diff is equally important! Here's mine...one of the funnier vids up there: hows you neck doing? that looks like some serious fun! I cant wait to get out there...
September 6, 201015 yr Some of those trails up in Walker Valley get pretty intense with rocks, holes, mud etc.
September 6, 201015 yr I've done it both on 27's and 30's. Would highly recommend 30's and a welded rear diff. And it's Walker Valley, not mount walker Edited September 6, 201015 yr by Markus56
September 6, 201015 yr Author I've done it both on 27's and 30's. Would highly recommend 30's and a welded rear diff. And it's Walker Valley, not mount walker yeah, i figured that out... for some reason i want it to be called mount walker:banana:
September 8, 201015 yr I've seen a couple of guys on youtube ( ) trucking through a mudholes on mount walker and i was just wondering what's the minimum tire size you recommend for that trail? 30's are about as big as you want to go, 235/75/15's or 30X9.50X15's they are for the most part about the same as for small 27's are the least you would want to run, I would say 30's are the least to go up there, you can make it with smaller ones but it picks your car up 1.5" over a 27 and that makes a difference.................... Jeff
