s'ko Posted February 24, 2004 Share Posted February 24, 2004 I noticed when driving that if I were to pump the gas pedal the tranny lurches and makes a clunking noises. It shifts fine and with smooth application of the gas pedal, there is no noise. ODO is frozen at 220k. Is this normal wear and tear for this mileage? What can be done to make it drive smoother? Also, when the 4wd level is disengaged, the transfer case makes a LOUD clunking noise. Is it normal for there to be a clunk when the 4wd is disengaged? I use to have a Jeep and there would be a little clunk when the transfer case was disengaged, but this clunk sounds really bad Also at what speed can you drive in 4WD? Link to comment Share on other sites More sharing options...
Guest taprackready Posted February 24, 2004 Share Posted February 24, 2004 Clunking noise when you feather the throttle back and forth is likely to be the tranny mounts which are usually always shot in a high mileage vehicle. Use the search engine on this board and investigate how to make your own urathane replacements. It will save you money and be a better product that trying to purchase factory stuff. Speed at which you can use 4x4 hi. Some may disagree but any speed from 5-105 miles per hour. It basically doesn't matter. Some may ask, "why would you have a need for 4x4 at high speeds"? Well there really is no need, but I'm just making a point that the vehicle will not be harmed by grabbing that lever and putting in 4x4 at any speed. You may experience some bucking/binding should you try to do it on dry surfaces and the steering wheel is not pointed straight ahead but otherwise no problem. Take care of the tranny mounts and the clunking should go away. Bill Link to comment Share on other sites More sharing options...
s'ko Posted February 24, 2004 Author Share Posted February 24, 2004 thanks Will do the search BW Link to comment Share on other sites More sharing options...
SUBARU3 Posted February 25, 2004 Share Posted February 25, 2004 The universal joint in the driveshaft will do the same thing .....if worn. I replaced mine and WHAT a difference! Todd Link to comment Share on other sites More sharing options...
