2007imp Posted September 27, 2010 Share Posted September 27, 2010 Just installed 4 new kybs in my 05 legacy sedan and now have a shimmy/vibration when going over 60. Could it need an alingment,It didn't have shimmy before. I made sure to mark the camber bolt and put back in orignal position.Could the new struts make the worn components be more felt ie balljoints/tierods/bushings. Thanks Quote Link to comment Share on other sites More sharing options...
nipper Posted September 27, 2010 Share Posted September 27, 2010 Usually a shimmy over 60 is a wheel balance issue, and yes it can just happen. Does it go away at 70-75? Rotate the tires to see if it moves. Quote Link to comment Share on other sites More sharing options...
bstone Posted September 27, 2010 Share Posted September 27, 2010 Can also be sway bar links. Quote Link to comment Share on other sites More sharing options...
94Loyale Posted September 27, 2010 Share Posted September 27, 2010 Agreed with Nipper, usually a tire balance/tire pressure issue. Loose inner tie rod ends will make themselves evident at that speed also. Quote Link to comment Share on other sites More sharing options...
2007imp Posted December 31, 2010 Author Share Posted December 31, 2010 Problem finally fixed.Front drivers side wheel bearing bit the dust.Now drives like new. Quote Link to comment Share on other sites More sharing options...
