September 29, 201015 yr 95 Outback. Just wanting to do some preventative maintenance. What are the grease points on the clutch cable system? I know on my BRAT it helped if I kept the pedal lubricated. Thanks. -Kyle
September 29, 201015 yr The only major one is on the release lever pivot bolt inside the bell housing. The rest of the cable system doesn't move much except for the cable itself, and you can't lube that. I suppose you can hit the pedal pivot with some lithium grease.
September 29, 201015 yr Yeah - pretty much the pedal pivot point is all that's accesible. The cable is dry-lubed and if that is comprimised the best solution is just to replace it for $25 GD
