Idle Air Control Valve 88 GL Wagon
My 88 wagon idles at about 1200 - 1800 when warm and barely idels when cold or I just start it up. I was told that my idle air control valve is bad and would cost $260 or so.
Is there any to fix this or is a cheaper to get one of these? Also, where is it? The only picture I have seen is on a 2.2 engine.
Mike Carey aka ekimyerac
My daughter just got her first car on her own 87 DL Sedan?
Your IAC valve mounts on the passenger's side of the throttle body. It has a big round connector. Look just behind your power steering pump pulley.
I assume you have a code 24 in the computer. There is a diagnostic tree to follow to make sure you have a bad one. See this link:
http://www.finleyweb.net/docs/SubaruEA82-ServiceManualPart2.pdf
and go to page 67.
BTW, when I did the testing, there was nothing wrong with my IAC, just the wiring. I ran a new wire from the driver's side firewall harness connection to the IAC and everything was copacetic.
P.S. the first half of that factory manual is at:
http://www.finleyweb.net/docs/SubaruEA82-ServiceManualPart1.pdf
everyone should have a copy (that owns an applicable car, of course!)
Still having trouble. Cleaned and installed, but, to no avail. Will check electrical connection soon and voltage.
Definitely check the PnP yards for IAC's if indeed yours turns out to be bad. You can yank and install a lot of used ones for $260!
