Console Back Lights - Cabin Temperature Slider
'98 OBW
Are there supposed to be some??? When I turn on my headlights I only get dashboard backlights - the heat/cool slider is in darkness - can't see where I need to slide :confused:
Steve
It's that way on my 97 OBW. I have the same question. I have to turn on the overhead light in order to adjust the temp.
There is a light that shines through to the vertical slit in the center of the slider.
It's pretty easy to replace those bulbs. And you can clean the stupid sticky heater buttons while you're at it.
There are a couple different ones in there. I can't remember which kind that one is.
The foglight, cruise, and rear defrost buttons on my OB weren't lit when I got it.
It took me almost a year to realize they were supposed to be. :-\
The heat level thing should lit up too.
I can take a pic of mine with the lights lit when it gets dark tonight if you want.
Edited by daredevil1166
  • 4 weeks later...
