Rebuilt ea82 wont fire
HI ALL! MY 92 LOYALE WAGON JUST GOT A BEBUILD ON THE ENGINE AND CAN'T GET IT TO FIE? ANY IDEAS? HAVE GAS, SPARK, IDK WHATS UP. HELP PLEASE:eek:
what are symptoms while cranking? is it popping? spitting, gurgling etc.?
Does it Make an Accelerated high Pitch Sound while Cranking? ... if So, it should have a Bad Timing, even if Belts are well installed, the Disty could be Off...
I Kindly Suggest to Check the Disty Timing.
Good Luck, Kind Regards.
definetely has the high pitch accelerated noise when cranking but according to book timing is correct but i'll double check the disty. thx
