November 25, 201015 yr Hey can anyone help me? Im trying to rewire my ignition because it crapped out on me. I dont know which Ignition wires are which, there are 5 wires ones black which im 99.9% sure is the ground, and there is a blue one that I get power to when I hook the positive wire to the + on the coil but I only get headlights, no heater or anything.... so im guessing that is just my on/off? and not my acc? which one is my starter wire? and which is my 12v? and also my acc if anybody knows? Just trying to get it going again I have to drive it to work friday... :-\
November 25, 201015 yr White wire = Main battery feed, 12V+ Blue wire = Acc feed to fuse box; heater blower, radiator fan Black w/white wire = starter Black wire = main ignition feed to fuse box; headlights, fuel pump, ignition
November 25, 201015 yr Author ah thank you so much i have been searching all night for that info.. you are a lifesaver! and happy thanksgiving guys
November 26, 201015 yr A new ignition switch is $32 from the dealer. Would be a lot simpler to just get one of those when you go for the permanent fix. I understand having to get to work, but don't leave it that way. GD
