EA82 leaking coolent from this pipe
I have a 92 loyale 4x4 with ~180k miles. Anyway I'm leaking fluid from this pipe that runs from the passenger side block to the intake manifold. Is this something that need a new seal or new part? do I have to remove the manifold to fix/replace the part to stop the leak? vwsigm.jpg
That's the EGR pipe. I highly doubt you're loosing coolant there :)
More likely is one (or both) of the tiny coolant hoses on the intake.
One is directly behind the throttle body and goes down into another metal coolant line. This one is 3/8".
The other goes from the thermostat housing, under all the wires in front of the intake, and into the block. This one is 1/4".
