December 19, 201015 yr I recently came across a '05 WRX STI engine with 27k miles on it for $300.00 so I bought it in an instant and I want to install it into my '93 EA82 Loyale 5spd 2wd, But before I do this I want to do my homework and make sure it will work. So can this be done with little modifications? Do I have to change out the transmission and suspension as well and the engine?? Any other advice will be appreciated very much Thanks in advance -493
December 20, 201015 yr Start here: http://www.ultimatesubaru.org/forum/showthread.php?t=73676 Read every reference link. Then use the search function to fill in the blanks. Head back to this thread if you have any questions after that.
December 31, 201015 yr Author I actually got everything even wiring! The WRX it came out of was wrecked in the back and he was parting it out.
December 31, 201015 yr Check out this engine completely. Remove timing covers, make sure all the pistons are there (no joke). That is juts too good a price. DO a leakdown test if you can.
January 4, 201115 yr I bet it's stolen. EJ257s don't have the VIN on the block or anything, do they? Jacob
January 5, 201115 yr Make sure the belt hasn't jumped and caused anything to bend. Also check the pistons too as the ringlands are known to let go and cause major blowby, especially when run hard.
