Where to buy JDM stuff?
Need parts to bring an engine back up to snuff. Anyone know where to get replacement parts or a website that shows parts interchangability?
You might start where you got the engine from.
Alright then I will. A few of the hoses (Metal ones) have rust and gunk in them and I think Im gonna replace them. Also the MAF to turbo pipe is cracked and Im going to need that too. Belts I figure I can get from NAPA or something. How should I clean out the PS resivior, the replacement you gave me has crud in it and the little filter was askew and I don't want to take any chances. BTW, did you pull that intake manifold yet? I've almost got mine off but I basically had to rip everything off the engine! Never knew it took so much to refurbish/ clean the OUTSIDE of an engine! When do you expect to get that wiring info? Thanks for your help Corky!
About 90% of all those things are the same as the Legacy Turbo. I think I have another MAF to trubo pipe I'll give it to you when I give you the good manifold.
You flush the PS tank with any parts cleaners.
You got to remember, those engine came here in a container after the Pacific Ocean, if the container wis near the top, it got a lot sea spray, and that salt is what caused the oxidation on the engine.
I should have the wiring info in about two weeks.
Man, you've got to be patient.
Hows it going removing the intake manifold? I have had to disconnect so many things to free it from the wiring and vacuum hoses!
How soon are you going to be putting the engine into a car??
Im working on it and want to get everything squared away so when I get a shell, I can work on that and have the engine done!
