97 Legacy gt hesitation
I just bought a 97 Legacy gt that the guy was in way over his head and now i'm thinking i might be also. He put in a JDM motor and drove the car about 10.000 miles and developed a hesitation, when a idle the engine runs perfect. When you try to speed up you get a hesitation and a little bit of a chuging, but at certain rpms it does smooth out and run good. I have a flashing check engine light and the code comes up p1101 Manufacture control fuel and air meter. also have 2 other codes po500 speed sensor a and po325 knock sensor 1 bank 1. Anyone have any ideas.
Thanks Steve
No ideas, common even an educated guess would be ok.
P1101Neutral Position Switch Circuit High Input (A/T)
P1101Neutral Position Switch Circuit Malfunction (M/T)
Check plugs and wires for the hesitation.
P0325 -Knock Sensor Circuit Malfunction
the hesitation could be the knock sensor. mine was old and tired and caused hesitaion under slight load, driving uphill. if i punched it it would eventually catch and go. mine did this for a while before it threw a code.
P0325 is actually a circuit problem that could be a connector or corrosion under the sensor, maybe. but depending on the miles, it may be due anyway.
P0500 - Vehicle Speed Sensor Malfunction
any speedo issues? does the AWD work properly?
if it is an auto trans, put the FWD fuse in and take a test drive. see if you can feel a difference. i usually can.
P1101 - Neutral Position Switch Circuit High Input (A/T)
P1101 - Neutral Position Switch Circuit Malfunction (M/T)
i have no idea about the last one? but it too sounds like a circuit issue?
