ea81 coolant leak(water in oil)
I just bought a 81 gl wagon. bought it knowing it had a leak. i drained the milkshake out of the oil pan and filter and put new oil and filter and ran it with nothing in the rad. (it was 23 degrees out) it ran great! turned it off and started putting coolant in it. rad would not fill up, but the oil dip stick did... and i can hear water running near the right head when i was trying to fill it. sure enough water in the oil. is this just a head gasket leak? or worse?
