January 15, 201115 yr Got a used suspension from a yard. The monkey that pulled the parts cut the rear lateral link off the crossmember with a torch, because he couldn't get the bolt out. Any suggestions for getting that bolt out of the frame side of the rear lateral link?
January 15, 201115 yr Pretty common to have to cut those actually. Depends on what you need but price a new bolt, etc before you fight it too hard.
January 15, 201115 yr Lots of PB Blaster and time. Many times they are rusted into the bushings so tight, you have to drive it out with the BFH and then get a new or used bolt.
January 15, 201115 yr Author Will they press out, without damaging the arm. Then I have to think about the one that is currently on the car. How did you cut them out, with a sawzall?
January 15, 201115 yr firsthand experience, don't buy the lateral link if the bolt is seized in it, go get another that the bolt comes out of. A yard sold my brother the entire crossmember so he could get his lateral links and we simply could not get them out of the crossmember it was seized at the inner bolt, poundeing, heating etc it was seized in the bushing. We took it back and found one car out of 5 at a yard that we could get the bolts out of. Luckily, on my bros car, the bolts came out fine. when you put it back together apply antisieze.
January 16, 201115 yr Author so how do you get them out of the crossmember already installed in the car? Changing the crossmember is not an option, the bolts for the diff are too rusted. Could they be cut out with a sawzall?
