Shifter bushing 82 wagon
The shift lever feels like a spoon in the soup...i guess it is the shifter bushing that needs to be replaced,but i cant find a new one here in norway. Anyone knows if i can modify it or do anything with it that will work??
What I have seen happen with mine is one of the pins in the linkage wears out and makes it flop around. I have drilled out that pin and put a bolt that's thicker through it and that seems to help quite a bit. Mine is doing this right now too, another thing I need to add to my list of things to fix :rolleyes:
OK,maybe i have to check that first. Are you doing all of this job from under the car?
