February 6, 201115 yr i have a 86 d/r and need to take notes on the clutch sizes the 7 7/8 disk is for FWD only correct? the 8 7/8 disk is for the 4wd d/r ?? its for a 98 legacy with the 86 d/r 21 or 24 spline? what other options do i have
February 6, 201115 yr When I went to napa to get a new clutch for my 86 Brat(EA81) they gave me a clutch kit for an 86 GL wagon(EA82) which is 24 spline.The pressure plate seemed to fit on the flywheel fine, same with the pilot bearing, but the friction disk was 3 splines to big for the transmission shaft. The 24 spline 8 7/8 should fit fine. I dont know about the 7 7/8 disk for FWD, mines 4wd 8 7/8
February 6, 201115 yr Author When I went to napa to get a new clutch for my 86 Brat(EA81) they gave me a clutch kit for an 86 GL wagon(EA82) which is 24 spline.The pressure plate seemed to fit on the flywheel fine, same with the pilot bearing, but the friction disk was 3 splines to big for the transmission shaft. The 24 spline 8 7/8 should fit fine. I dont know about the 7 7/8 disk for FWD, mines 4wd 8 7/8 i read ofter hours of searching and it ways the 21 spline is for the hatchback and brat some sites seem to mix the diameter and splines up which made it hard on me
February 6, 201115 yr IIRC 21 spline is for EA81 2wd/4wd and EA82 N/A 2wd. 24 spline is for EA82 4wd and 2wd turbo.
February 7, 201115 yr Ive found rockauto.com and also this ebay seller a good source of clutch dimension and spline count info. http://stores.ebay.com/gripforce-clutches_Subaru_W0QQ_fsubZ18QQ_sidZ98015562QQ_trksidZp4634Q2ec0Q2em322
