Automatic transmission chart?
I've seen the manual transmission chart posted here, that has all of the gear ratios. I'm wondering if anyone has that info for automatics.. I have an 03 Baja/ manual that needs a differential. A local yard has an 03 legacy/auto, and I'm trying to figure out if the differentials match. the 03 manuals were 4.11.
Thanks
Thanks
You'll need to know the trim/model of Legacy it came out of, I believe, as the GT may be different from an L....and make sure they're not still using the Legacy Outback as a description.
Choices from cars101.com:
Legacy L Sedan
Legacy L Wagon
Legacy L Special Edition sedan
Legacy L Special Edition wagon
Legacy GT Wagon
Legacy GT Sedan
I did a quick search of the '03 Legacy Owner's Manual (downloaded from "My Subaru" site) but didn't see it listed in there.
Also, looked @ Car-Part.com and looks like 'maybe' the MT have 3.9 and AT's were 4.11, but again you'll need to verify the exact model.
I've also read where you can email Subaru of America - w/the VIN # - and they can tell you.
GL,
Td
Edited by wtdash
^ That is cool. The Gear set-hypoid section shows the ratio.
Under HERE.
